I have used my brand new Acer Predator X34A monitor for a few days, but I have discovered a problem with G-Sync. With G-Sync turned ON and the frame rate capped at 100fps in Assetto Corsa (racing game, if you don't know), I discovered some frame tearing at exactly 100fps. Capping the frame rate at 99fps solved this. But I tried Nvidia's pendulum test, which confirmed that G-Sync will only work up to 99fps on my monitor.
The blurbusters frame rate test shows a valid 100hz refresh for my monitor.
So what's next? Should I send the monitor back for RMA or is there any fix for the G-Sync??
