Why are these drivers like double the size? 800+ megs for a display driver?
Decompressed size is over 800
Any good then?
That's a big ass driver.
Morning chaps.
Anyone had issues with silly high ping when enabling relive?
Installed the update yesterday and played some overwatch, everything was running smooth at around 29ms. Today however, i have set up relive and now my pings around 300+ms!! Even when not streaming it doesn't come down.
Morning chaps.
You on wireless by any chance?
I highly doubt it is AMD drivers affecting my wireless connection but it did seem odd that the problem started around the same time as putting relive on...
I can't see the chill settings, should I be seeing them in wattman somewhere?
If you not streaming then I highly doubt the driver is the making your ping high.
The is a network issue, under task manager is the anything hitting the network?
My wireless connection went to ****, it seemed like the ping was really high at times, so bad that players in the division would freeze and die 5 seconds later from an entire mag I put into them...
Switched to hard wire connection, no problems.
I am back on 16.11.5 due to having 2 lockups yesterday, have yet to try my wireless out again but shall report back later.
