- 10 Apr 2014
- Hampshire
got my RX480 ready top be put in my system but first I need to buy the watercooling components. for the water blocks there are a few(I think) to choose from , here they are ...
https://www.overclockers.co.uk/ek-water-blocks-ek-fc-rx-480-wc-9bm-ek.html
https://www.overclockers.co.uk/xspc-blade-radeon-rx480-water-block-wc-40o-xs.html
https://www.overclockers.co.uk/ek-water-blocks-ek-fc-rx-480-acetal-nickel-wc-9bk-ek.html
https://www.overclockers.co.uk/ek-water-blocks-ek-fc-rx-480-acetal-wc-9bl-ek.html
https://www.overclockers.co.uk/aqua...ic-glass-edition-nickel-plated-wc-31h-aq.html my favourite in looks
https://www.overclockers.co.uk/aqua...n-rx-480-acrylic-glass-edition-wc-31g-aq.html
as for choice of backplate ,I haven't decided yet. are all these compatible and which would be the best in terms of cooling? or are they all just as good?
going to go with this tubing ...
https://www.overclockers.co.uk/monsoon-petg-tubing-16-12mm-id-1-2-od-5-8-4x90cm-clear-wc-303-mo.html ... what fittings do I need?
all advice welcome (Y)
