Eurocarparts Triple QX oil any good?
Yep, pretty sure Shell supply it.
Although having said that, I've found Shell oil to be cheaper. £18 for 5litres of 5w40 LL01 Shell oil. Bargain!
Used it in my B5 RS4 - it's not blown up...it meets the correct specs so it's fine.
I think a lot of this oil hype is just that. Oil is oil really...regular changes I'd say are more important than spending a mega money on mobil 1 or something
I love the idea that oil is rated as "good" because an engine hasn't immediately blown up.
How are people measuring long-term engine wear, because this is what actually matters.
Depends in what you call long term.
I change the oil in my car every 4-6k miles.
I know i don't particularly need to, but I do anyway.
I just changed it today, along with an engine flush and 1/4 a bottle of SPT oil additive added to the new oil. Will see me through to April I think.
Agreed - but who has ever been able to measure and present the data of long term engine wear?
Every manufacturer claims their oil leads to less engine wear but I've never seen an independent, scientific test into it. You just have to trust that what is written on the bottle is true and that the reputation of giant companies like ECP would be in the toilet if it was found out their own brand parts were not as claimed.
Americans do this a lot and it originally came about from the "Kwik Fit" type places making false claims that it lowered engine wear in order to sell more oil services. It is just wasteful and damaging to the environment to change your oil every 5k, unless you live in a very cold country, you do lots of very short trips, your driving is almost exclusively in heavy traffic or you do track days.
:eek: I don't throw the oil down the drain..!
I take it to a local garage who then dumps it in their used oil barrel.
The car sounds better after an oil change. It's what I have done every since I bought my own car :/
Would have to be an independent test running identical bench engines under identical load conditions for the same duration's and cycles, its just complex and expensive.
We need to remember, Castrol don't employ sheds full of people just to sit in a lab and read the newspaper, i'd rather pay a little more for an "expensive" oil under the knowledge that at a minimum it won't be any worse than the cheap stuff.
