Failed to Enumerate objects in this folder.Access is Denied
Caporegime
24 Dec 2005
Autonomy
I upgraded my HP Microserver running Drive pool and windows 8.1 to a Dell T20 running windows 10
I enabled the administrator account
I added my own account as a local admin and made sure I was in the admin group ( same username as before)
I have the same account on all my PC's and the same password.
After installing windows 10 on the new machine I installed drive pool and scanner
I then transferred the pool and Drive pool found and balanced all the drives.
I can TS onto the server using said account on all my machines around the house.
From My Gaming PC I browsed to \\server\X$ and get a "Enter Network Credentials pop up.
I add my username and password but this just appears I try again and it just appears again
When I log in as administrator as above.. I can connect to the share \\server\X$
Why can't I connect when I user is in the administrators group? But the administrator account can?
Anyway I took a look at the permissions of X and Both my user and administrator had full control and the owner was administrator
I clicked "Replace all child object permissions with inheritable permissions from this object" and get this error for some of the folders in the share
I want to be able to access the share from my user account from any PC in the house
When you're connecting to the share are you using:
servername\administrator
administrator password
Or just Administrator and password?
Try the servername one.
M.
M.
I can connect to \\server\x$
with
administrator
password
server\administrator
password
But I can't connect with
user
password
server\user
password
even though the user account is a local administrator and part of the admin group!
Just seen the permissions screenshot. You need to take ownership of the folder first.
Change the owner back to administrator - I bet the SSID for the old admin account is present and stopping access.
Alternatively add a new user and give them permissions and test.
M.
M.
I have ownership of that folder
The owner is administrator
and my user is part of that admin group.
