Corolla T Sport
22 Mar 2012
Need a car to fit these requirements:
£1k
25mpg or more around town off peak times
Extremely reliable (16-20k a year mostly town driving)
Fun
Practical
This and the Primera GT were the answers I came up with, but the Primera GT seems to be extremely rare and disappears fairly quick when they come up for sale under £1k. So is the corolla a decent choice for this sort of critera? Any owners that can share experiences good or bad? Any weaknesses to especially look out for on these?
I did find this which looks like decent to me:
https://www.gumtree.com/p/toyota/20...eather-fsh-12-months-mot-tsport-px/1206100818
In my experience if you are doing that kind of mileage and want something "extremely reliable" you want to stay away from anything with more than 100k on it or it'll be in the garage getting wheel bearings, drop links etc. half the time.
I'd probably, no definitely drop the "fun" requirement and instead focus on finding something reliable and more importantly comfortable, if you plan on doing 20k a year in it.
Maybe an Accord or possibly an older Volvo.
A 3mm pin triggers the sliding mechanism on the seats. It is prone to breaking and requires some fettling to repair or a new seat. Both driver and passenger side went on our Corolla.
The gearstick chrome finish flakes
The bulb on the dash dies
The paint on the spoiler flakes
The headlights are prone to clouding
The headlight connector is prone to burning out
If I think of anything else I'll let you know.
If you listen carefully, you can hear Acme breathing heavily around a corner.
It will keep pace with most hot hatches from the same era in a straight line, but it handles like a horse on stilts unless you invest some money in suspension modifications.
The Facelift is slightly better as it had revised suspension, but your budget doesn't really allow for one.
They are solid cars if they have been looked after properly, but sadly they are of an age now where they are likely to have been abused at some point. Aside from the usual second hand car stuff, few things to look out for:
  • As mentioned above, the seat slider pins can snap, I had to drill mine out on the drivers side and I replaced them with bolts with tapered ends.
  • Clutch release bearing chattering on the overrun is common if the kit hasn't been done for a while.
  • Oil leaks from the cam cover are common, as are they from a seal on the back of the cam chain cover. Both are easy to rectify by simply replacing the seal and/or the gasket. Check down the back of the block with a torch and a mirror if you can.
  • Camshaft flange bolts (lift bolts) get worn and snap which may cause the variable valve lift to stop working, these are easy to change, plenty of guides online. I'd want to give this a look on higher mileage cars. Make sure lift engages at 6200RPM. The early ones are more prone to this issue because Toyota later revised the metal the bolts are made out of, so they were stronger.
  • Gearbox whine in first gear is fairly common, but not "normal", be cautious. Mine whined like a straight cut gear in 1st.
  • It is quite common for the heater matrix to stop working, make sure it blows warm air.
  • The dash separates from the bottom of the centre vents/radio surround slightly, which is annoying.
  • The flap on the centre console will almost certainly be snapped off... :p
However straight line performance is excellent, and you should be able to get 40MPG+ on a run if you take it steady. A combined average of about 30MPG should be easily achievable.
They come with a decent bit of kit as standard too, proper automatic climate control, auto wipers etc... :)
Other things to consider for 1K.... Clio 172 maybe? Those little MG's based on a Rover 25 are dirt cheap also, and you may get a Focus ST170 in budget too. But really another £500 would go a long way if you can find it.
The practicality requirement pretty much eliminates an MX5 otherwise I'd recommend one of those, out of the other four I'd definitely have the Corolla. Is it the best car all round? Probably not. I'd guess thats the Clio? But this noise!
I'm not sure if I'm out of touch. However the following don't tend to belong with eachother:
- Fun
- Reliable
- 1k
They can do to some extent. MX5's for example will usually tick all of those boxes. If you added 'not rotten' to your list however...
I just bought a 3 litre x type for a grand. Hasn't exploded yet :p
Plenty of S types and Xjs out there too.
Having said that I suspect the power steering pump is a bit grumpy.
Well, my celica t-sport hasn't really cost me anything in the ~18 months I've had it (and I purchased the cheapest, roughest one around lol), so I would expect a corolla t sport to be a good, reliable car.
What needs to be practical about it? Because the celica is going to be a vastly superior car apart from only seating 2 in the back and less boot space (though impressive for a coupe)
Its a bit tiresome on the motorway if you like to cruise at... well in excess of 69mph though. I would be surprised if the corrola wasn't much better in that regard...
Ive got to be honest, i think that's terrible advice. Especially considering OPs budget. Practically the only sub 100k cars in that bracket are cheap hatchbacks which often aren't the most durable cars.
Cars with larger displacement tend to be a better bet at this price. They are often better looked after as running costs would have been less of a concern for previous owners. instead of buying some <1.4 car because the previous owner wanted to save £60 a year in tax, you can imagine that they likely did the bare minimum to keep that car maintained.
Its a shame 306gtis are rare these days. Otherwise Id recommend them. I loved mine at the time.
Its a bit tiresome on the motorway if you like to cruise at... well in excess of 69mph though. I would be surprised if the corrola was better in that regard...
I did 2500 miles a month in my Corolla T-Sport for a while. It wasn't too bad really, but by no means quiet. The engine sits at fairly high revs when cruising at 70. From memory its around the 4K mark. The Celica was a fair bit louder, but the seating position was far more comfortable.
Corolla would just about manage 45MPG if I did my Worthing to London commute at 60 - 65MPH, but 38MPG was a more realistic figure without actively trying to get your economy up. Never attempted to drive as far as London in the Celica incase the body panels fell off.
(Dont be concerned by my comments about the Celica OP, it was a Brumy chop shop ex-write off special)
Oh, I'm familiar with the saga of you and your celica GT, dont worry about that.
Mines been incredible though. Crazy cheap to buy, supremely reliable, enough performance to put a smile on your face and just a properly well built car. Everything still works and feels tight, best £1,100 I ever spent TBH.
But I'm sure there are plenty of dogs out there, I just lucked out maybe.
And I dont do that many miles, maybe 1,000 a month. But the sound from cruising on the motorway is slowly killing me lol. I should really do 70, as its fine then.
I think I damaged my hearing from driving the Celica with the interior stripped back to metal. The engine/exhaust noise was incredible though... Much fun... And then a cable tie would snap and all the undertrays would fall off. :p
