I've had 102,000 views on my YouTube video, what now?
you have a few subscribers.100,000 views isnt much.at all.
I've had my channel since 2006 and I've amassed over 600,000 views. My e-peen is swelling. :D
YouTube has changed it algorithms recently and it's been causing havoc for some YT'ers. People been randomly unsubscribed all over the place. I would keep a close eye on your subscriber base to make sure it's not happening to you.
As for the money you made, buy your partner something nice, it is Xmas! ;)
Does the algorithms affect the search results?
I've treated my fiancé enough this year. Time to treat myself :D
Since your video title is exactly the search term I'd use for finding help probably helped it significantly.
Wouldn't bother reinvesting (not sure how you'd do that anyway bar buying ad space). Spend it on whatever you want.
I don't believe it effects search results, but for a lot of users they have noticed random massive drop offs in their subscribers. Less subscribers means less views and less revenue if you have a popular monetised channel.
I wish YT wouldn't dick around with the site. It worked fine before. Idiots! :(
