Broke Vertagear PL6000 what to buy next?
21 Jun 2005
Supposedly this stone can take big weight, I weigh 90k and the chair is warped, I tried to fix it last night and ended up breaking it even more so now the chair is unusable.
I never really found the chair to be too comfortable to be honest, I found after weight training it just hurt to sit in so I'm looking for something a bit more comfortable. Don't really have a budget as such I guess £400 tops but if spending more will net me something a lot better then fine, I just want to be comfortable. I'm 90k and 190cm.
Thanks
I wouldn't call 90kg that heavy tbh. Any half decent chair should be able to do up so say 120kg no bother.
I know there is a few folk at work who weigh more than that and they don't seem to be breaking chairs on a regular basis.
DXRacer
Classic Series Gaming Chair - Black/Grey OH/CE120/NG
Best chair ive had so far, and Ive had a few!
Large and comfortable, although the built in headrest could do with being a little softer, but maybe thats just me.
BTW....My Vertagear Racing Series P-Line PL6000 Gaming snapped in a strange place aswell.
90k is not far off the average weight for an adult male, so it sounds like you just had a faulty chair. You should get on to vertagear for a refund / warranty replacement.
Maybe you had one of the 1st revision chairs. Because they have a 2nd revision and I think it fixed that issue.
