New tubing needed?
10 Apr 2014
Hampshire
Since getting my rig watercooled , i hadnt realy thought about checking the resevoire for dirt or a build up of gunk. i looked in the other day and saw a mirky mark in there, checked again a couple of days later and it was worse.
then i had a proper look at the tubing itself, i noticed dirt specs, tryed wiping the tubing to make sure its inside and it is. bought a fresh 5L of mayhems H20 2 kill coils and a Blitz cleaning kit, will that be enough to sort the problem or will i need tubing?
even now im posting this from My xbox one S, dont wanna use the PC unless i need to.
If you're talking about adding kill coils I guess you just had water in the loop before without biocide, is that right ? if not what fluid/biocide were you using ?
Personally I'd replace the tubing anyway as it's cheap and new tubing always looks better.
i dont think there was biocide in it. as for the coolant , its just mayhems H20 and mayhems uv green dye.
