This would be perfect, Auto, 4WD, Nav
http://www.stratstone.com/search/ve...es--automatic-diesel-white-hatchback-yf16sfe/
I'd happily have a 6-12 month old car as it will basically be like new and still under warranty
It would only be for 18-24 months
What would be the easiest way to purchase it? I rather not put down anymore then £2000-3000
Mrs won't let me get golf, said it's too common
[TW]Fox;30342336 said:Yea because the 118d is super rare
A quick glance on howmanyleft suggests there are more 120d/118d M Sport than there are Golf GTD on the road.
How much would the BMW m140i cost ?
But that will be counting the old shape too
I've used the vag sat nav info system it's so slow and horrible to use
What version of the VW infotainment did you use? I've just gone to the newer 'MIB2' system from a 'MIB1' and the difference is night and day.
Bigger screen, higher resolution and zero lag when doing anything.
With the MIB1 there was always a delay when issuing commands, for instance waiting for the sat nav to come up with your choice of routes took an annoying amount of time.
Tried out the nav on the newer version today and it was instant with the route options, and just better overall.
. How about some driving lessons?
Sorry, who are you?
Someone who knows how to drive.
Why do you think a powerful car needs 4WD?
Powerful fwd dont grip good in wet when setting off
