£150 to spend, but what on?
23 Jul 2009
Bath
Got some ocuk vouchers for Xmas and I'm trying to decide what to spend them on. It's not enough for a cpu/mobo upgrade, but I'm trying to work out what would actually be a worthwhile upgrade. Bit stumped really.
Current system:
3770k, 16gb RAM, 980ti, 500gb ssd, 120gb ssd, 250gb ssd, 2tbHDD,1tb HDD, 500gb HDD. All in the original phantom full tower. Happy with my headset, kb and mouse.
Considering refreshing my case with the phantom 630. Either that or maybe an AIO cooler to replace my massive air cooler. Any other suggestions?
Sound card, speakers headset ?
All sorted. I think the only proper upgrade would be cpu so I am in the weird situation of just spending it on something potentially cosmetic. The case option would open up a lot of airflow options so it's at least somewhat functional!
Even considered a NAS box to move some drives out of my main pc. Not sure how worthwhile that is though?
Nice discount on a gsync monitor if you dont't have one?
I do, but thanks for the suggestion. Common sense seems to dictate that I should just save up for something worth getting. So for that reason I'm going to get a new case. Then when I do get a new cpu and motherboard I'll have a nice case to build it in. Yep, it's burning a hole in my pocket
