Cooking Fats And Health
25 Jun 2009
Weston-super-Mare
Am I the only one confused by this subject?
A while ago, I read that posh olive oils etc are great cold, but bad for you when used in cooking due to their low smoke point, and that when oil smokes its bad for you cos reasons?
So I've been using rapeseed / groundnut oil for my roasting / frying
Now I see apparently that's bad for you cos reasons, and I should be using oils ultra high in saturated fat (which I've been told are bad cos reasons) such as coconut oil, and even lard because of reasons.
Well I've had enough. From this day on, I'll be using whatever fat the recipe traditionally uses. I'm a fan of the Mediterranean way of chucking tons of on oil on everything and roasting it, so cheap olive oil will probably be my go to roasting oil with rapeseed being my go to for frying.
Any thoughts? Am I missing some kind of absolute concrete proof that I should use certain oils for certain things?
Coconut oil, (not the stuff mixed with other stuff)
Seemingly this has the best resistance to the flavenoids (i think) which is the stuff bad for you from cooking at temp)
We use olive oil almost exclusively now. Lard is supposed to be ok too believe it or not.
some fats are good for you.remember all the oldies cooking with lard.people used to mock them now they like oooh its good for you :p
Cook with the cheap vegetable oil (rapeseed) and a cold pressed rapeseed oil for salads.
Chips have to be done in beef dripping or I don't bother. Bacon gets a knob of butter near the end.
Frying with butter is great. For extremely long high temperature frying perhaps not but for most things (e.g. steak) it's awesome.
I used butter, sunflower/rapeseed oil, olive oil, goose fat or sesame oil dependent on what I'm cooking. Last time I had my blood work done it came back really good
Coconut oil has a ridiculously low smoke point compared to some - it's good for light frying maybe but not for stir frying or steaks. I tend to use rice bran oil for most things as it has a much higher smoke point. It has a very neutral taste so I add a bit of butter to finish things off if I'm feeling that way inclined.
I have loads of goose fat leftover from Christmas so might try that as an alternative for extra flavour.
Extra virgin olive oil has a low smoking point but light olive oil has a very high smoking point,one of the highest.
Furthermore, for things like frying onions for a sauce then you want a low temperature so virgin olive oil is fine.
Butter is good. Yes at very high temps it will burn but that is actually OK, but t butter has a great caramel taste and is widely used in cooking. That is why butter is typically used for steaks, adds to a great taste
Coconut is OK to add a bit of coconut flavor to Thai dishes etc but has a low smoke point. Even then I will typically use the cocunutbbutter atvthe bottom of a can of coconut milk, that is what they use in Thailand etc.
For the most part, a refined natural oil has a high smoke point. A non-refined (or "virgin") does not. Ghee vs butter, virgin olive oil vs 'light' olive oil, etc.
