Yesterday I was driving with the Mrs when a notification popped up on the dash, Rear Brake Lamp Fault (or words to that effect), pulled up and confirmed the left brake light wasn't working.
Picked up the correct bulb this morning, changed it and works fine. Got in car an hour or so later and when I started the car up the same warning message popped up again, checked all lights just to make sure a different one didn't go. All fine, I decided to change the other rear brake light as I got a pack of two bulbs, still same issue, brake lights work fine, message is still displaying when I start the car up. After a quick search online some people suggest making sure I acknowledge/read the message so it's not listed. Done this and still stumped. Is there anything else I can check before I take it to Ford to have a look at bearing in mind I'm only used to basic car maintenance.
The car in questions is a 60 plate Mondeo.
Thanks.
Thanks.
