). It worked well and was quiet at the same time
Yeh the noctua is a little on the fuggly side
Doesn't bother me though as I'm not a case window kind of guy![]()
If that's the case for anyone, I'd always go with the Noctua D15. It's really the king of air CPU coolers, and looks aside, it can't be faulted, and super easy to fit as well. D14 comes a close second, but I think the R1 pips it. That is bigger and has potential RAM clearance issues with X99 though, and possibly PCI-E socket interference on some mobos. Cryorig have an origami thing you can download and make from their website though, which is super handy.
The D15 is a quality item. The packaging, instructions and materials all scream quality. It also performs very well and is whisper quiet. Only downside really is that it is enormous.
