Only about 25% is actually being used (mostly by windows) of the 16Gb.
Have found that it is also getting:
02/01/2017 06:44:24 | Enigma@Home | Reporting 3 completed tasks
02/01/2017 06:44:24 | Enigma@Home | Requesting new tasks for CPU
02/01/2017 06:44:27 | Enigma@Home | Scheduler request completed: got 0 new tasks
02/01/2017 06:44:27 | Enigma@Home | No tasks sent
02/01/2017 06:44:27 | Enigma@Home | Message from server: Enigma 0.76b needs 13482166625837707296508455294996900044251027422596401029782012726271763384636952730618783393505932024335246350758056564557460147738613726978611546151458668996605602112795106310885474304.00 MB RAM but only 16268.52 MB is available for use.
02/01/2017 06:44:27 | Enigma@Home | Message from server: Enigma 0.76b needs 3633355906759967822163392472118519509897936333762380538799349237146650150447872889552536326477638749902077901780791787612123406287017170888293484786718292115578013593460801536.00 MB RAM but only 16268.52 MB is available for use.
02/01/2017 06:48:30 | Enigma@Home | Sending scheduler request: To fetch work.
02/01/2017 06:48:30 | Enigma@Home | Requesting new tasks for CPU
02/01/2017 06:48:34 | Enigma@Home | [error] Can't parse file info in scheduler reply: unexpected XML tag or syntax
02/01/2017 06:48:34 | Enigma@Home | [error] No close tag in scheduler reply
The XML error occurred after at least 5 hours of the memory message and getting 0 new tasks (and no problems with tags).
Now if I update it gives the error and backups off even more, suspect others will be getting it, they are getting the memory error.
Hopefully it will eventually sort itself out (WCG had a similar problem last year), but that box will be going back to Gene as well when it finishes the last few in the cache to be done
Hopefully we have enough to pull it off.
