I played Witcher 3 with its normal set of settings, and I didn't have them all at max. I was nowhere near 144fps most of the time.
I took you at your stated word/numbers.
Well you'll not if you use the same FTW card as me, that the witcher 3 absolutely maxed out at 1440p hits anywhere between 45-90 fps depending on the given circumstances.
I would say for 144hz you would need to turn down some settings, starting with hair works.
FYI im not trying to disagree with you lol.
