- 26 Sep 2013
- West End, Southampton
Hi guys.
Need some advice on the best way for me to control the fan speed of 6 Vardar fans I have in push/pull on my front rad which cools my two GPU's in the loop?
I've got 12 fans in total, 6 on each rad, one rad in the top of the case which cools the CPU, these 6 fans I have on the case fan controller so these are not the problem.
The ones I need to control are the other 6 in front of the case. They are 4 pin PWM Vardars https://www.overclockers.co.uk/ek-water-blocks-ek-vardar-f4-120er-2200rpm-wc-867-ek.html . My mobo only has 3 pin fan headers, how would I go about getting a solution to controlling these so they are not constantly blamming away at 2200rpm?
I was wondering if something like this would do the job? https://www.overclockers.co.uk/phanteks-pwm-fan-hub-ca-009-pt.html Bit confused though as this only looks to take 3 pin fans. There is also the NZXT one but that also looks like a 3 pin one only.
I should also add I've also no spare drive bays so it would need to be external solution of some sort. I've been looking around for a 4 pin to 3 pin Y splitter, but looks like no such thing exists so I'm clueless really.
