The purple shift is annoying, seeing them glisten in the rear view mirror out the corner of your eye it almost looks like flashing blues![]()
On the fleet vehicles with these fitted, you turn up the sensitivity lever from 0-3. That basically decides when it activates the wipers in heavy, medium or light rain. The wipers come on at normal speed. If you don't want them on, switch it to 0.
You have manual control between single wipe, off, intermittent, normal and fast.
Automatic High Beam Off, at that point. Call it what you like - I'm talking about the headlights that are supposed to detect oncoming vehicles and auto-switch to dipped beam.[TW]Fox;30377454 said:Can you clarify what feature you are actually talking about?
It is literally as described. One slider on top of the arm controls sensitivity. Position 0 is off. 1 is heavy rain, 2 is average, 3 is light mist. The higher the sensitivity, the sooner it comes on.They don't. I suspect the wipers in the astravan work very similar to other auto wipers on the market, but he doesn't know how to use them, i.e. set headlights to Auto and wipers on intermittent.
If you say so - The car is clearly as uninformed as me then, or the guys at BT Fleet who showed us exactly how it worked when we all got our vehicles...[TW]Fox;30377531 said:Turns out he is talking rubbish, from the Vauxhall Astra owners manual
The worst thing about auto wipers is when your engine is running and you are scraping ice / snow off the windscreen, you can end up with a cold surprise thrown into your face haha.
Can't say that's ever been a problem as you shouldn't leave an engine to warm up stationary anyway. I scraped the sensor clear first then do the rest of the screen, never had it go off on me.
I had it with the mazda which has always auto-on wipers so no need to activate it like on the BMW.
sprayed some window cleaner on while engine was running and got splashed right in the face with it, not the nicest of tastesthat was a cheap halfords window cleaner wonder if auto glym tastes any better.
bmw system not so stupid then?![]()
It's different.
mazda simply goes - auto wipers? -> sense rain/water -> on
bmw requires you to manually flick the sensitivity or stalk to first activate the wipers and then it manages the speed/turns them off.
But on a more serious note, why not?
What would you do if you had a modern Mercedes then?
The window is steamed up until it gets warmer and I'll be damned if I'm getting into a cold car![]()
