Spec me a VPN!
Caporegime
24 Oct 2012
Yer nan's knickers
Afternoon you lovelies :)
I need a VPN for my matched betting. Hoping there's a free option out there but otherwise I don't mind spending a few bob. I've used Private Internet Access before which had all the bells & whistles but was a tad on the slow side so looking for something a bit faster.
Any ideas?
Cheers :)
I used IBVPN. Free trial but not much after. Don't use anymore though so don't know what recent updates and locations are like.
I use Private Internet Access. I can't say I've noticed any speed issues with it either. If you definitely don't want to go with them, I've heard some good things about flyvpn.
I use Private Internet Access (PIA) for my VPN. No logging, loads of POP's in many countries and if it's important to you then you can purchase with anonymous monies like Bitcoin.
is there a way of using a vpn on a firestick without having a vpn router. Im using a Virgin super hub 2. I have tried using openvpn on the firestick but cant figure out how to get one of the vpns on it such as nordvpn ? any idea please
I've been using NordVPN for all my internet access for a few months now and it's been fine. Speedtest shows a consistent 47mbps, 50ish without - I can live with that.
The only annoyance is if you dl p2p without changing to an enabled server first it forces you on to the default one (in the Netherlands) which is really slow.
I found PIA to be sporadic at times, and kept having disconnection issues.
Moved onto AirVPN and found it to be OK but then tried PureVPN which I've found to be by far the best of them all. Best part was the lifetime subscription for $69, so I opted for that.
It's been perfect since, and very easy to use.
I use OctaneVPN via TheCubeNet, got it on a New Year deal a few years ago for $1.99/month.
Does a decent enough job :)
Just found out that I still have an active PIA subscription. Completely forgot about it!
I'll give it a go for a week or two and see how it fares. Hopefully it's better than last time I used it, or I might have more luck. Thanks all :)
