- 28 Jun 2005
Hi. Looking for some advice. I've had the rig below for about 5 years and it's only ever been used as an ESX host - never gamed on it or overclocked it. I want to turn it into a music production workstation but I'm not happy with the temps the current cooler is showing. At idle (with just music playing, for example), RealTemp is showing an average of 52c across the cores. When I'm using a heavy VSTi in Ableton, the temps head into the 70's causing the CPU to throttle and the output from Ableton to go choppy and drop out.
From what I can tell, this CPU should still be able to cut it with music, especially with an overclock to 3.8Ghz+ but I need to sort the cooling out. All slots on board are filled and the memory is running at 1066 due to running 24GB on this board. Happy to drop that to 12GB if I can run the memory at a higher speed.
My question, is should I be looking at a new cooler or try and figure out why this one is not cooling as well as I thought it would? The board is running with optimised defaults currently. Budget is up to £100 if I can squeeze more performance out of this rig for a while.
Intel Core i7 960 3.20Ghz (Nehalem) (Socket LGA1366) - Retail
Gigabyte GA-X58A-UD3R Intel X58 (Socket 1366) DDR3 Motherboard
Corsair Vengeance 12GB (3x4GB) DDR3 PC3-12800C9 1600MHz Triple Channel Kit x2 (24GB)
Fractal Design Define XL Full Tower Case - Black Pearl
Corsair Enthusiast Series TX 650W V2 High Performance Power Supply (CMPSU-650TXV2)
Corsair Hydro H50-1 High-Performance CPU Watercooler (Socket LGA775115511561366AM2AM3)
Akasa AK-FN058 Apache Black Super Silent 120mm Fan - 4 Pin PWM
Windows 10 Pro
Thanks for looking.
Windows 10 Pro
Thanks for looking.
