Seems expensive for a what it is really, might just have to track down for a a second hand Lapps with a mobile graphics card then.
Thanks for the reply
The GTX 980M is comparable with the new GTX 1060. You could possible get an older model with a 980m for under a grand if you shop around.
You sure? I thought it was like an old desktop gtx 770?
I need to do some research
The 980M is a great card and clocks really well.
Here's mine with a 4th gen I7 - http://www.3dmark.com/3dm/10136433
More comparable to the desktop GTX 970.
