Scenario:
I have a 2 x144hz monitors one with Gsync,one without and my game runs between 80 -100fps at all times.
Is there any benefit of using Gsync because there will be no tearing or Input lag if I don't use any *sync* (vsync = off)
Scenario:
Scenario:
If you are using the non Gsync monitor with vsync off and getting 80-100fps then there *will* be tearing.
Why? Does tearing occur when you are rendering less frames than the fixed refresh rate of the monitor ?
