I noticed that I was a bit cold this morning, the air coming from the vents was cold. Temperature gauge was in its normal position. About 10 minutes later I notice that there was heat again, which then cycled to cold air. It did this a few times and settled on cold.
Is this likely to be the thermostat itself or the housing? Really want to avoid spending any money on it so if it's something I can fix at home that would be most welcome!
If you really don't want to drive your other car you don't have to.
