Hi all,
first things first:
CPU Q9550
MOBO https://www.msi.com/Motherboard/P35_Neo.html#hero-specification P.S. i assume that manufacturers link shouldn't be a competitor, if it is then let me know i'll remove.
RAM Kingston 2GB PC2-6400 DDR2-800MHz non-ECC Unbuffered CL6 240-Pin DIMM Memory Module Mfr P/N 99U5429-007.A00LF
HSF Cooler Master Hyper TX3i with Prime95 (running have seen tops 55C)
So at the moment i lifted it up @3.2Ghz no problem, runs prime95 over 1 hour with no crashes. so started lifting bit more up but nothing good. crashes/freezes/RR/ you name it i have it. I'm running MSI DUAL CORE CENTER where it shoves core volts @~1.125 and on BIOS is AUTO, but if i change on BIOS to the same value as i see on DCC and increase speed it crashes. This is my old pc just want to mess about with OC to know whats what, but from where i see i can't go nowhere higher or am i wrong?
Some pics http://imgur.com/a/2BUa9
BTW i managed to get @3.7 with changing volts in bios but after then it just started to crash so put all down to run on auto voltages @3.2. So now just looking for an advice, because i been told that with my mobo i can't do much. Check link below
http://www.userbenchmark.com/UserRun/2571571
first things first:
CPU Q9550
