Spec me a laptop please
24 Aug 2006
Will be using it to run Visual Studio for .net web development
Think I need
i5
8GB RAM
SSD
15.6 inch display
I have a 1440p monitor that I'd like to connect it to
No DVD required
Budget is £400-500
Found this
HP 250 G5 Core i5-6200U 8GB 256GB SSD 15.6 Inch Windows 10 Laptop for £410
Is a i5-6200U going to struggle to compile code?
It's not really an issue.
Ive seen an Asus vivobook with i5 6300HQ, which is quad core. Bet that's a lot better, but it's £750.
Yeah, the 6300HQ is a lot faster. There's a nifty CPU benchmark comparison tool on this page (6300HQ vs 6200U).
It really boils down to how much of your working day you're waiting for the VS compiler to finish versus how much you're willing to fork out.
As you might know, VS supports "parallel builds" which takes advantage of all available CPU cores (unless you deliberately lower the number in Projects and Solutions -> Build and Run), so a 4 core CPU would probably be a smart choice in the long run.
£550ish can get you a "Asus N551JB Intel i7-4720HQ 8Gb 1Tb nVidia GeForce 940M 15.6" 1920x1080 Win 10" manufacturers refurb
edit: Although if you are going refurb, you could just buy something second hand. I reckon something with the older i7 3 series is worth up to £300 second hand and might be an option.
You can find it on the .co.uk site of one of the biggest and most well-known online retailers in the world if you search for "HP EliteBook 8570w" - the 2nd result shows a couple of used ones for £475 (albeit with a slightly better CPU), and the 3rd result is the one for £499 (there's currently 10 in stock).
Does that help? :)
Does that help? :)
Cheers
The seller is being dishonest though.
New != Refurbished
New
HP Elitebook 8570W i7-3740QM @2.70GH 16GB 750HD Win 7 Pro - 1 YR Warranty THESE ARE CERTIFIED REFURBISHED WITH 1 YEAR WARRANTY
Cheers
New != Refurbished
New
Yes, that applies to the i7-3740QM version which is listed as an alternative 'new' Elitebook 8570w. But if you look at the i7-3610QM version (the one I mentioned above) they've got 10 in stock and there's no mention of them being refurbished.
That being said, it can't hurt to ask the seller to confirm that they're definitely new. You never know...
Alternatively, just buy a different quad core laptop - I'd be surprised if this is the only option in the £400-500 price bracket... I wonder if Dell might have a similar model on offer.
Is this recommended
HP Omen 15-Ax095na Core I5-6300HQ 8GB 1TB + 128GB SSD GeForce GTX 960M 2GB 15.6 Inch Windows 10 Gaming Laptop
£759
Or are there better for this price?
Seems expensive when the 1050 version is under £800 I think
The 1050 version also comes with the slightly better 7300hq etc:
Latest generation Intel® Core™ i5-7300HQ Quad-Core processor
39.6 cm (15.6") diagonal Full-HD (1920 x 1080) display
8GB RAM with 128GB SSD and 1TB storage
NVIDIA® GeForce® GTX 1050 (2 GB GDDR5 dedicated)
edit: Its £829 but there are codes for money off etc to bring it to around £780
Cheers
