So you are getting a 32.5% increase from 1080 to TXP
You are then getting 22.6% increase from TXP to sli 1080 or a 62.5% increase going from single 1080 to sli 1080.
Can I just ask what the core clocks are to get an idea on if you are are on the upper limit of what either the 1080 or TXP will clock at or if there would be room to push or if you have been lucky/unlucky with the silicon lottery.
Edit: Thanks for the post.
Which sounds great but of course is £2320 outlay in GPU alone for that.
Some healthy gains between the cards there. Although scaling isn't awful 62% isn't great either. I wish they would sort out scaling tbh. I am pretty sure they always sandbag sli in my opinion so not to give such a boost over that of their higher models.
Witcher 3
All overclocked
Screenshot taken at exactly the same spot to show fps.
Max settings 2160p.
Single 1080
Single Pascal Titan
1080 SLI 2 way
For comparison here are a couple of overclocked Pascal Titans doing the same.
Pascal Titan 2 way SLI
I have a prolimatech mk26 with 2x140mm fans cooling my 980ti, would this actually be able to cool a Titan xp? It keeps my ti at around 55-60 degrees maxed out and + 200 on the core?
Witcher 3 has always had crap scaling in my opinion. Many other games that scale a lot better than this. 62% aint bad yes, but could be better.
Ti is hopefully bound to come around april,well at least to be announced, then maybe we'll have them in june or more. Thing is, Titan X P is here for the taking and 1080ti will not overpass titan. I personally own one and am glad I didn't wait for ces dissapointment. Am watercooling it asap and will pull 2.1 ghz off it and live happily ever after![]()
