Dunno about a stagger, but the camber looks a bit... off at the back?
Yes I need to get it lifted a bit at the back so I can straighten them up. It's booked in for another alignment next month so will be done then.
Sorry I got my terminology wrong, I think camber is what I meant.. like you see on a drift car?
Although that effect usually applies more to front wheels
Righto guys!
Hang on a minute, I thought snow foam WAS a pre wash?!
Actually I used a snow foam thingy for the first time last night, seemed to do a reasonable job for basically no effort, bit of a pain having it freeze on the roof though.
What about the pre-pre wash?
Too cold for me.. I did manage to clean the wheels last week though.
Still not completely happy, as they get dirty pretty quickly. I think some of it comes from the brake pads?
Would a wax be any use?
Well I was all excited about the foam and was up for buying my own one. In the light of day though, the car isn't that clean and the real killer is that it's left covered in hard water marks, overall looks worse than it did before I think. Not the magic solution I thought, probably be a lot better with purified rinse water.
