- 1 Dec 2015
Interesting question for users on hear
Bar brand loyalty or even knowing which brand the card belonged to, Would would put first and last for selection a GPU?
Say if you were going to pick a GTX 1080 , which would you pick first and last to determine your card of choice
1) Base clock speed,
2) Temperature recorded at that base speed,
3) Power draw at that base speed
secondly , do you automatically set your own fan curve ?
If you don't would you consider doing so if the Card was too loud even though temps and clock speed were fine?
or if the card temperature was to Hot for your liking yet doesn't throttle or sound to loud??
personally if, looks and branding where taking out of selecting a card long with warranty etc etc etc
I'd pick Speed, Temp and then power draw based on a GTX 1080
And I always customise my fan curve, turning off idle fans to have some sort of air flow over the card at its lowest RPM speed, and then start a curve from 50c to 80c being at 70% of max RPM
sorry, could have used better grammar and structure but at work and was thinking about it
**if a mod could personally word it better or add two polls please feel free
