8Pack Binned 5ghz+ Delidded 7700K CPU's for sale at OCUK
OcUK Staff
20 Feb 2012
John Smiths Stadium
So here we have it, the first retailer in the UK selling binned Kabylake CPU's. The first retailer in the UK selling delidded CPU's with full OCUK warranty. No need to invalidate your warranty anymore or Bin CPU's locally!!!
The key features of this product are:
-Guaranteed 5g+ Core Overclock in all none AVX applications. All games and most professional applications are non AVX.
- CPUs binned by myself and delidded by our technicians with Liquid Metal replacing original Intel TIM for upto 30c cooler running temps.
- Full 1 year warranty with OCUK
- Free Thermal Grizzly 1g TIM so as to get the best thermal bond with your heat sink and hence great cool running.
The components used for binning these CPU are as follows:
Asetek 240 AIO cooler (We suggest at least this level of cooling for efficient stable operation)
3200mhz 16gb Corsair dual channel Vengeance mems at XMP
Nvidia GTX 1080
Asus Strix and ROG motherboards and Gigabyte Gaming 7.
1200w Quality Gold PSU.
Stress tests used:
Real Bench stress test.
None AVX Prime 95
XTU CPU stress test with 3D running (Heaven or Valley Maxed out!!!)
Suggested settings for 5g:
- Vcore 1.32-1.39v load typically 1.35v needed at most.
-VCCSA 1.00 -1.10v for 3200mhz mems Upto 1.25 for DDR4000mhz +
-VCCIO 1.00-1.10v for 3200mhz mems. upto 1.25 For DDR4000mhz +
+warranty upto 1.425v load if you want to push further.
The hardware we recommend to get the best from these CPU is:
Motherboard in ASUS Strix, ROG range or Gigabyte Aorus.
AIO cooler with 240mm Rad or higher, lesser cooling may work fine but is not guaranteed to.
Quality Bronze rated or above PSU providing enough quality power for the entire system.
Here is the link to this power users product:
https://www.overclockers.co.uk/inte...a1151-pre-binned-processor-oem-cp-003-oe.html
So an extra 110 quid?
Well I'm sure some people will be lining up round the block.
Personally I can't afford it.
Cool to see thou.
I have three kinda similar can run upto 7050mhz 05 and even 6600mhz cache......... no problem!!!
How many 7700Ks did you have to bin to get these?
I'd love to know the percentage of these chips that are capable of a steady 5Ghz+ overclock.
Mr 8 Pack, what dimms do you recommend to go with the 5gh chip for 4000mhz, o have tried to get hold of galax hof with no joy. I was eyeing up the teamgroup ones
