So I recently purchased a Lian Li PC-O8 Case and moved my rig over from the Cooler Master Haf X.
I do plan on open loop watercooling as this is what the case is designed for however until then any help would be amazing.
Heres the current specs;
i7 3930k 3.2GHz
16GB Corsair Vengence Ram
2 x 4GB EVGA GTX 680 (SLI) Reference Cards
Corsair AX1200 PSU
CPU is cooled by Corsair H100
Here are how the fans are connected;
CPUFan - Corsair H100
CHAFan 1 - 4 = Main bay exhaust and 3 front fans.
Both rear fans are connected via molex.
I'm aware that the GTX 680 4GBs run hot as standard as they're reference cards.
These Temps are Average;
Idle Temp for my CPU is 45°C
Idle Temp for top GPU 44°C
Idle Temp for Bottom GPU 51°C
Load Temp for CPU 60°C
Load Temp for Top GPU 85-95°C
Load Temp for Bottom GPU 85-95°C
I am lead to believe that these temps are the cause of the fans being high throughout the entire case which is making the case very loud, Much louder than in my Haf X (Which has good air flow).
Any help towards the temp or noise issues prior to watercooling the entire rig would be amazing.
Cheers
i7 3930k 3.2GHz
Corsair AX1200 PSU
Cheers
