Asus Maximus Hero IX m.2 slots
7 Jan 2017
Morning All,
Quick question and probably a fairly obvious one. Did spend some time googling but couldn't figure it out.
The HERO IX has x2 m.2 slots.
m.2_1 which supports PCIE & SATA
m.2_2 which supports PCIE Only
Now if you had a PCIE drive in m.2_1 which had windows and all the like installed, is it possible to move that physical m.2 drive to the m.2_2 slot without having to re-install windows?
This would correct an error as that drive was installed in m.2_1 first, the additional m.2 drive that is wanting to be installed is only SATA so can not work in m.2_2. This would then allow the SATA m.2 drive to be installed in m.2_1.
Many Thanks
Morning All,
Many Thanks
It will be fine.
