With Adobe Premiere Pro better off with a Nvidia card as Adobe Premiere is Cuda capable as that will speed up the rendering process. Also more RAM and overclock the CPU too.
GTX 1050.
. Something like a second hand 290 with a decent cooler ...
290 which one is that Nvidia?
Doesn't recent versions of Premiere Pro now work better with OpenCL compared to CUDA now? AMD cards would be the better choice.
I use Premiere Pro but have found that although my 980Ti does a very fine job of rendering, the 7970 provided smoother playback where transitions are concerned, whereas over time the performance from my Nvidia card has become noticeably poorer in that regard. Personally, if it was me buying right now, I'd be looking for an AMD card for PP. Something like a second hand 290 with a decent cooler or if buying new, then the above mentioned RX 460 should be fine.
I see they're just about to put up the price of subscriptions. :/
This, Adobe are flatout neglecting nVidia propitiatory support and nVidia would rather not support Open Source beyond just having it, which they see as a threat to their business model.
You're much better off even with a seemingly much weaker cheaper AMD card than an nVidia mega card.
Nvidia's recent consumer cards haven't really been optimized for compute: http://www.anandtech.com/show/9306/the-nvidia-geforce-gtx-980-ti-review/15
