I have a 4770k PC upstairs that I use as my office machine and I have a 6600k downstairs for gaming.
PC upstairs you press power and flick of lights from front of case and nothing.
1st - Took PSU from PC downstairs and still nothing
2nd - Ordered new motherboard and installed. PC now turns on but screen says no signal
3rd - Try using HDMI port and DVI port on motherboard with no GFX in, same No signal but PC seems to stay on fine
4th - Put GTX770 from gaming PC downstairs still shows no signal
5th - Put gaming PC on monitor (Check monitor) all seems fine (HDMI only tested)
6th - Tried PC with only 1 RAM stick etc... Same seems to be fine but shows no signal
WTF should I do? Could it be the CPU? Even tho PC seems to run, I cant think what easy tests I can do now without buying anything new?
Please help, Thanks in advance
Sheldon
Sheldon
