- 19 Nov 2011
Hi all just got a project bike which has been sat around for a while, and looks a little sad and run down.
She is a late reg K2 (Just like my other SV!
) and she is now called mumbles. Seems like a fitting name.
At the moment I have identified the following things which need to be looked at:
She turns over - and at the moment will not start, fuel seems good though. I had the odd sputter, but not much more - need to check for a spark on both cylinders if she doesn't fire up tomorrow.
The fairings have been covered in grout, yes grout of all things :smt104 so I will need to clean those up and see what damage lays underneath, if they are bad I might have it re-sprayed in British Racing Green.
Here are some pictures of how she looked when I picked her up:
The above pictures where fresh out of the shed - looking a bit naked (ooerrr!)
These pictures where when she arrived in my garage - to the right is my baby done quite a lot of work to that bike too mainly a bar conversion, she is ready for the ride to Le-mans this year!
Stay tuned for the next update!
) and she is now called mumbles. Seems like a fitting name. At the moment I have identified the following things which need to be looked at:
- Rear Subframe Rust Removal and Re-Spray
- Front Subframe Rust removal and Re-Spray
- Both front and rear brakes to be re-built
- Correct the choke (The choke switch just springs back?) No idea on that one yet
