Looking for a specific light switch
LiE
LiE
Caporegime
2 Aug 2005
Milton Keynes
When we had the kitchen done a specific style of switch was used for plugs and lights switched. I'm trying to buy a few more specifically for the piece of plastic that surrounds the metal. This is needed because 86mm isn't wide enough for the hole I have. These measure 91-92mm.
Any idea where these are sold ?
personally I ditched those annoying plastic surrounds, because they don't look particularly good and therefore aren't really serving their purpose.
although that doesn't actually answer your question :p
They look fine on a white wall. The issue is without them there would be a small gap around the plug. The other option would be to fill and sand the gaps.
Thats the Click Deco range.... that should help your googling :)
Beat me to it. I am slowly replacing the switches in the house with this range as they are very well built and easy to wire up.
I buy them from alert electrical as they seem to be one of the cheapest places and happen to be local
