I've just bought an SSD for my laptop (a dell inspiron 5520), and had intended to install windows 7 on it (as came with the original laptop) and use it as my main drive, with the original drive as a 2nd hdd. My computer came with an OEM version of windows 7 preinstalled, no backup discs.
When I came to download windows 7 from the microsoft website, it said my product key was invalid (oddly, the product key on the laptop sticker differed from the product key found when using those scanning tools you can install) and to contact Dell. On speaking to Dell, they advised that their installs are different and only dell specific windows installation discs will work, for which they wanted to charge me £50. Pretty irritated at that sort of cost, particularly given you can buy generic OEM licence keys for not much more than a tenner - i don't really see any point in buying the dell one. But rather than spend that tenner, just thought I'd check here first
Final ancillary question - when I was looking in the bios I noticed that it didn't give an option to access a USB port specifically - the options were hard drive, optical drive or network. Would my laptop be able to read an installation off a USB stick therefore (I presume, considered as a 'hard drive') or is my bios not able to read USB sticks on startup?
Thanks a lot!
- Is this standard Dell behaviour? Somewhat disgusted if so and would certainly put me off buying from them again. I had always been under the distinct impression windows OEM installs could be reinstalled on the same machine (even if different hdd)? In which case charging to be able to do that is plain wrong!
- Is there any legitimate way around it? ie. Dell customer support was just trying to pull a fast one and there is a website where you can download their windows OEM version to install on a new HDD, free of charge. I also read somewhere that I could call microsoft and see if they will simply activate a new windows 7 install - does that stand a cat's chance in hell?
- If I buy a generic OEM licence, I presume I could just use that to download windows 7 from microsoft and do the install using that?
- Slight query around the two different product keys - at one stage I installed windows 10 on this laptop as part of the free upgrade, then rolled it back as I didn't like it. Could that be the reason for the two different product keys, in which case could a windows 10 install work instead?
Thanks a lot!
