Dark Knight Parvum ROG Build
2 Aug 2016
Third Earth
Evening!
Just before I leave on holiday for 2 weeks, I've fitted together some of the bits of my new build.
Parvum Veer ITX
Asus Strix Z270I Gaming ITX Motherboard
Intel 6700K i7 CPU
32GB RAM
2x M.2 960 Pro's
Titan XP with EVGA Power coupler
Water cooling - 440mm combined of cooling rads 1x240, 1x120, 1x80 - acrylic tubing will be used!
I'll be taking it apart again but for now, here's some money shots!!
When I get back from holidays, I have an additional week off to complete this build, so will update it then.
Hope you enjoy it :)
very nice. i have a rog build, few years old now but does the job. will post mine up soon.
Post up some pics! Give me inspiration!
What was the case like to build in?
Yep it's good, I've had many problems with Parvum though, but should be ok now. It's good that you can whip a panel or 3 off so access is good.
Thanks I have been thinking about getting one.
If you do, consider the following:
1) If you go with a standard build, it will take a while (couple of months)
2) If you ask for customisation, it can take considerably longer (going to extremes, but on other forums people have waited a year) but I stress this is extreme.
3) They come with no filters
4) Depending on the model you go for, you may have problems with the GFX bracket
5) When it arrives, check all panels fit together properly, it's been known to get wrong panels (happened to me)
Sounds bad I know but they're good guys, just struggle to keep up with demand, but the cases are good, they are completely customisable by them or you, the limit is your budget and imagination!
Lots of beautiful builds out there, give them a chance but be paitent!
