Can I SLI 2x960 cards on this Motherboard (Z170-E)?
21 Mar 2005
Hi.
I have an opportunity to pick up another 4GB 960 graphics card.
I had no intention to run SLI previously!
I gather the cards will run at the slower card's clock speeds and they need to both be 4GB.
I read somewhere something about Skylake CPU's taking lanes and SLI not working properly..?
So just wondering really should I expect to be able to run SLI using these?
Cheers :)
MSI
GeForce GTX 960 Gaming 4096MB GDDR5 PCI-Express Graphics Card - Red
KFA2
GeForce GTX 960 Reference 4096MB GDDR5 PCI-Express Graphics Card - Retail
Asus
Z170-E Intel Z170 (Socket 1151) DDR4 ATX Motherboard
Yes you can but I really wouldn't want to. Too many chances of multi card problems cropping up. A single faster card would be my choice and the RX480 is over double the performance of a GTX960. I would sell the card you have now and put that money towards a RX480.
Okay cheers.
I agree with what you have said but I'm getting the card cheap so.. Will give it a whirl.
Presumably you have made sure that your power supply can handle a second card?
It did cross my mind however it's not the most powerful of PSU but a good quality brand...
Super Flower Golden Green HX 450W "80 Plus Gold" Power Supply - Black
Hopefully it will work! If not I will still use the new card as it's MSI 4GB Gaming compared to a "reference blower".
Running my setup through a power calculator gives this result which is on the wire
Results:
Load 409W
Recommended 459W
Your psu has a 444w 12v rail so be prepared for a lot of fan noise. Running it at near full capacity is going to ramp the fan up to full speed continously. To be fair that load rating the calculator gave you is probably at the wall so the psu will not be delivering that much to the components.
Thanks for the info there
960 should be a good sli card with it having 4gb of ram and i GPU that cant use it all, the second GPU should do well in games that support it.
i would want 550w of power as a minimum.
tbf my system with 290x's in CF only used around 400w in game its benching that really eats up the power.
