- 25 May 2011
Which doesn't cost the earth!
Did you forget about your thread in graphic cards?
You'll be lucky to get 4K @ 30Hz at that distance - even half that distance is pushing it for 60Hz - I think there are 1-2 cables that were tested to just about manage 60Hz at 8m with some marginal stability issues (EDIT: Looks like 7.6m is the longest "certified" length that it should work).
EDIT: Amazon basics in my experience so far have all been fairly decent gauge wiring so probably the best bet you'll have of any.
To be honest though I wouldn't buy any of them - they aren't likely to be properly tested.a)Since I have the product and am using it why would I lieAnd getting 4K@60Hz at 10m? all the user reviews say it only does 30Hz.
yet if you search for the word 30hz in all 216 reviews only two occurrences, hardly most.I was asking for confirmation that you were running 4K @ 60Hz as you don't mention it just said it works (often when people say it works you subsequently find they are actually doing 1080p@60) and achieving that combination at that distance is not easy - if you read the reviews most say they can't get over 30Hz (didn't see any from a quick glance that specifically mentioned sucess at that combination and a lot that reported failure).
I think you are misusing the terms 'some' and 'a lot more'.Ah you are looking on Amazon - even there some saying stuff like "BUYER BERWARE…THIS CABLE CANNOT PASS 4k, 4:4:4 @ 60Hz signal", etc. though there are some that do claim they have 4K@60 working but a lot more that say they don't - not all use the term 30Hz (a lot don't mention what refresh if 4K or don't mention resolution).
I know from experience 4K@60Hz is often not plug and play especially at nearly 2.5m beyond the distance the signal is expected to attenuate below stable in the ratified standards.
It does look very much like that but it's sat in the loft over my head so can't check to be sure.
