Upgrade for 200 quid?
Caporegime
3 Jan 2006
Chadderton, Oldham
Hi all.
I'm thinking of upgrading and need some advice.
With a budget of 200 quid I just want to bring my pc in sig forward to current tech and maybe give it some future proofing or at least last a good 3 years or so and would like advice on what I should upgrade on this pc like maybe cpu and move etc.. And if 200 would do it? Cheers.
Occasionally gaming, GTA V, more console as like sitting at the sofa, and streaming movies and stuff, web browsing and all that I use my surface pro 4.
128gb SSD and radeon 7970 3gb
Not sure what my CPU compares to these days I bet it's probably slower than an i3? Totally out of the loop these days.
This is what your going to get for £200 the G4560 is a very capable budget cpu with 2 cores 4 threads it very close to I3 performance.
Review.
http://www.techspot.com/review/1325-intel-pentium-g4560/page4.html
My basket at Overclockers UK:
Total: £209.87
(includes shipping: £9.90)
your sig says you have an AMD 5870 ? You are going to need more than £200 unless you want to look for 2nd hand bargains.
It was a long time since I fully updated the sig I forgot, but yes It's got a 7970 in it and a 128gb SSD.
