- 12 Feb 2009
- London
As title I'm considering getting a full rgb lighting system for my build. Is the hue+ the way to go as I see corsair has something similar out now.
phillips is a rip off. much cheaper alternatives available which do the exact same job for cheaper.
even lifx IMO is a rip off but it's still 30% cheaper than HUE
I'm doing exactly this with an LED strip this weekend hopefully - I went for a solid color rather than RGB (wasn't sure I'd have space behind the motherboard for the white control block) but it looks simple enough and should perform better than a lot of the PC specific LED strips I've seen.Sorry its a late reply
Don't get any of these kit things
Get a £12 RGB LED strip kit from ebay, solder yourself a molex onto the connector which goes into the white controller block. You get 5m of lights which you can cut and use the other end of elsewhere for £15 including controller, a good remote etc. Don't need to use a crappy 5.25" bay controller thing, and it is much cheaper and more customisable
