HP NC364T PCI Express Quad Port Gigabit
Permabanned
21 Sep 2013
I have 2 of these, 1 on each machine. Linking them is CAT5E to a Dell N1548 switch. When I transfer it does spread the loads across all 4 ports. I get about 90/100mb transfer speeds. Was hoping it'd do more. Anything I can do?
Thanks
Server 2016 and Windows 10. No config on any of the cards. Just a file share between the 2 machines. Was a 30GB file
Not personally used Server 2016, but it still needs configuring as a "Network Team", and as far as I know will need the switch configuring (e.g. via LACP) as well to enable more than 1 NIC to be used for both send and receive.
Some references:
https://technet.microsoft.com/en-us...reate-a-new-nic-team-on-a-host-computer-or-vm
http://www.technig.com/configure-nic-teaming-windows-server/
2012 but still relevant
https://blogs.technet.microsoft.com...server-2012-do-i-need-to-configure-my-switch/
Are you sending one thing or multiple? As I understand it, if only one stream it will use one port. If a second stream starts it can use a second one etc.
