Xenons improve the front end massively on these. Assuming from the image you didn't retrofit the washers, but did you retrofit the levelling sensors?
Actually think chrome looks better, looks classier. The black grilles tend to be favoured by "M badge" brigade.
They are not OEM xenons they are from DEPO (Eurowagons) They are a direct swap with no modding required at all
They only require washers when fitted from new. Hate washers anyway.. always spoil car spraying all over bonnet
Ahh I see. Wasn't querying the legality, just wondered if you'd have issues fitting OE ones as it would expect the levelling and washers to be there.
shh you, its a great film![]()
Oh wow is that a 15 plate?![]()
