Well, I've completely uninstalled AVG on both (using the dedicated AVG uninstaller), and re-installed again.just let WU finsh and reboot some updates turn off A/V and as its a Windows build update it will
As orc said I remember reading about a couple of free AV breaking after windows applied updates. To be fair not that I have anything against free AV, as they are probably abusing your data and bombard you with adverts (that's why they are free) I would either stick with Defender or get a reputable one for your budget.
Its not their fault that windows causes them but they need to be sharp in support. At least with paid products you can hound them or trust there is some mechanism to engage with if such a problem arises.
Anyway, in before x product is garbage use z or anyone who uses AV instead of restricted accounts etc![]()
Sorry, but if you make unfounded comments like, "as they are probably abusing your data and bombard you with adverts," it's hard to give the rest of your comments a lot of credence? Sorry...
Fair enough...Well if you are keeping blinkers on then I dont really care. It only takes a short Google to find thousands of pages with references with "credence" over a guy posting on a forum but each to their own.
http://www.avg.com/gb-en/privacyWe collect non-personal data to make money from our free offerings so we can keep them free, including:
- Advertising ID associated with your device;
- Browsing and search history, including meta data;
- Internet service provider or mobile network you use to connect to our products; and
- Information regarding other applications you may have on your device and how they are used.
Fair enough...
But let me guess, you don't use AVG but somehow can tell me about how much it's, "abusing my data and bombard me with adverts," when I have it on five machines, where it's been in use for many years, with no data issues, and the only adverts are periodic suggestions (eg: months apart to turn on feature X or time to upgrade).
Blinkers or not - Given I've had positive first hand experience, on multiple machine, over multiple years, why would I possibly, a) change that belief by the views of someone who most likely is not even using it, and/or, b) Base it on a bunch of random posts on google?
But, as you say, each to their own - You much be switching and changing your views by the minute![]()
Does that really matter? I don't get Ads with AVG that often maybe once a week and with the way nVidia collect data along with plenty of other software they can see all the porn I fap to any day of the week.
Neil I have used it within the past year in between Panda and Avast when I was testing a few out. In fact my students have exposed me to a few laptops of their own with all the free AV for the past two years so I would like to think I have a valid opinion.
Well if you only admit to using AVG (as per OP) 'for years' then how would you know any better? These forums are great, you get people asking for advice, then you post and get arsey replies.
8. Privacy; Processing of Personal Information The Software collect s certain information, which may include personally identifiable information, from the compute r on which it is installed, including:
8.1 URLs of any websites you have visited ;
Oh... And the Windows update also screwed my Plex server too (on one of my machines). That required an install too!
I had recently changed to Avast free & snooping is prevalent as zhokel said
