Hi guys.
I bought a second hand motherboard off ebay for my i5 2550K as I wanted to OC the CPU, but I ran into serious trouble.
The board is GA-Z68MX-UD2H-B3 (rev. 1.0) mATX board. When I got it, I updated to the latest UEFI bios and managed to OC to 4.4GHz, at 4.5 I got bluescreens and hangs. It was not 100% stable at 4.4 as the computer froze irregularily.
I did some reading and managed to figure out that I could increase the LLC (can't remember what the setting is called now), and I got it working last night after some trouble. The voltage was a bit high however and 1.5V so I wanted to take it down a notch and set the value to +0.100, so that it went from 1.245 up to max 1.35 or so.
Problem is that this morning it wouldn't boot, it was stuck in a boot loop. It booted to a black screen for a few sec, after a few attempts it went to DualBIOS screen and rebooted again, rinse and repeat. Yesterday I also had to reset the main BIOS from the dual as it got corrupted.
After I had tried all sorts of things, reset with clear CMOS, taking out the battery, turning the PSU off and turning back on while holding the start button to force the DualBIOS etc, it just came on 1 sec (clicked on) and then reboot, 1 sec - reboot...
I am now out of ideas as I have tried all I could find online and it doesn't work. I had to reinstall my previous ASUS H61 mobo and that works like a charm, but with no OC functionality. Is the board totally dead and I've just lost £50, or is there anything at all I can try?
Specs:
i5 2550K
2x4GB Crucial 1333 RAM
MSI R9 390 8GB
1TB + 1.5TB HDD
DVD burner
Aerocool 600W PSU
Specs:
i5 2550K
MSI R9 390 8GB
1TB + 1.5TB HDD
DVD burner
Aerocool 600W PSU
