Valve Headphone amps
31 Jan 2008
S Wales
Anyone else use one? Bought a bit of chinachina off a popular auction site recently and I am utterly stunned by the sound quality of it (Nobsound 6J9). Bought it on a whim as it looked kinda funky and I had aspirations of building it into a case but its so small and well made I'm not going to bother.
Bit of a revelation for me :)
Man of Honour
13 Oct 2006
There are a few on here that do use them.
My personal opinion having spent awhile recently playing with building a lot of different amp designs is that the go to opamps that are used in most solid state setups like the OPA2132/4 and NE55xx series combined with often cheapest possible capacitors, etc. really don't do solid state justice and hence even a half decent tube amp will sound far more lifelike - with a little more expensive capacitors and better opamps I've got far more improved results than your average consumer audio or even a lot of higher end stuff that is far more competitive against a good tube amp.
EDIT: Not sure what headphones you use either but another aspect I find is that solidstate headphone amplifiers tend to focus on amperage in high power designs while tubeamps often by their nature work with a lot of voltage - and I've found headphones like the HD600 series are really transformed when they are driven with decent voltage swing, etc.
25 Jul 2012
Ankh Morpork
The Nobsound is actually a hybrid amp that uses the tubes as pre-amps to "warm" the sound signature a little and then uses an op-amp output stage for power.
Apparently the stock Chinese tubes are not the best quality so you can improve on what you already have by swapping them for something better, just make sure that they match the configuration. You can also fit different op-amps, though this will likely not make as big a difference.
28 Mar 2005
Drunken badger punching
I have a Xiang Sheng 708B with about 80 quid of high quality capacitors, resistors and other bits lobbed inside. It's very good although it does only have the original valves in, so I should probably swap them out for something in-line with the rest of the amp at some point.
20 Dec 2004
Hertford, UK
I have the Bottlehead Crack as well, with speedball. It makes my HD650s sound wonderful. I've been so impressed that I also built their Kaiju 300B speaker amp earlier this year and it is completely amazing. Though expensive!
13 Jun 2009
Chesterfield
very nice! i was really tempted as it seems like a cool project to do, but knowing me id **** it up and waste the money
