- 25 May 2011
Ahhhhh, I see.
Well I will test with some actual games and see how it performs.
Would installing a all in one water-cooling kit help Vs my NHD15?
if you question relates to the thermal throttling that's NOT the option you want... you cannot (I don't think) turn off thermal throttling, if you could disable the option your CPU would likely blow up (well I guess intel build in some tolerance you dont want it literally getting within 1 degree of blowing up)What's the bios setting called? That runs the frequency much lower when not needed, but still has the headroom when needed to 5.2ghz.
Speedstep?
