If you had a wall mounted PC (or just even an external watercooling system) is it possible to have it running off a large reservoir right at the top, with the water running down through the system into a lower reservoir where the pump just returns the water from the bottom to the top?
Would that work? The idea is that the pump can be run slower (quieter) and the water will naturally want to run down through the system, the pump is not really doing anything other than moving the water from one reservoir to another.
