- 12 Feb 2009
- London
So had a 2010 Astra 1.7CDTI A17DTR for about 7 months now but recently my wife had the DPF light come up as it normally just tootles round town. I took it for a bit of a blast on the Autobahn in 5th at about 3k Rpm to try give it a clear out.
Suddenly there was a load of what looked like white smoke and the one end of the engine making a nasty banging noise like two hammers been hit together. I had it recovered and read the ECU which gave a fault with one of the injectors.
I removed all the injectors for a look at the ends and refitted them along with a different used injector with the old copper injector seals. The car ran without the nasty noise but was still smoking abit and after a short drive I checked the oil to find it had risen with lots of Diesel in it.
Last week i refitted the injectors after giving the face of where the injector meets the head a good clean and fitting new copper seals and also changed the oil. Now it ran as it should with zero smoke or noise but again I checked the oil and it had diesel in it again. Ive read the ECU and it now has zero fault codes.
I want to try and figure this out myself before paying someone.
My next plan is to compression test it through the glow plugs leaving the injectors in place which im guessing will not only test the rings but also the injector seals?
Ive never compression tested anything but ive read they should read about 370psi for this engine. Im hoping it may atleast narrow it down to say a certain injector not sealing properly.
Does this sound like a good move to make to rule out piston rings before I go and pull the cam cover off again and have the injectors serviced at £400?
Thanks
Thanks
