- 18 May 2010
- London
for AMD it's called Freesync, you can find them here
Ouch! So you cant do it from the driver?
i somehow thought you were talking about freesync, which made more sense to me.Ouch! So you cant do it from the driver?
Amd do not have adaptive vsync anyway though right?
I set it on all new when I had my 1070 and found it to be great. My monitor is 60hz though even in game which did not get to 60fps I found it helped smooth out things. My guess is when not enough frames it used adaptive vsync.I wish they (nVidia) would put more work into FastSync - its brilliant with like 75Hz non G-Sync monitors, etc. when it works but still a lot of times when the results are less than ideal.
One of us needs to go and look again, Theyre two seperate things, Vram and a cache, Personally I won't be taking claims that it negates the need for more ram without any adverse effect when ram usage exceeds the 4gb's on chip without a big pinch of salt. I'll believe it when I see it working for myself across all games.That's why they are now referring to the HBM2 memory as being a high bandwidth cache instead of VRAM because it's not used in the traditional sense where all data is just lumped into the memory.
So AMD neither have adpative vsynch or fast synch driver side?
That would actually be a big deal to me as although the plan might be to upgrade the monitor at some point, it does incur an additional cost.
Until recently I ran a 3GB card fine on 1440p and it would still cut it today mostly but that isn't going to last forever and 4GB seems potentially a bit limited going forward if developers do actually start squeezing more out of the VRAM with next generation effects when they are less limited by having to accommodate the memory usage of the API.
Adaptive vsync is Vsync, tha's something all vendors have, Nvidia/AMD and even intel IGPU, it's software.So AMD neither have adpative vsynch or fast synch driver side?
Adaptive sync is Vsync, which AMD has in driver and games juste like nvidia.
fastsync, is like Vsync tripple buffering, but with lower latency downside, but it's really a hit and miss and still a mistery on how it really works, since there is no extensive testing or review for it ( that i could find )
as far as i know fastsync need extremly high framerate (x3 the fps) over your monitor refresh rate, or the best use is in tandem with Gsync monitor, still maybe someone who actualy have tested can explain it to you.
but so far basing your purchase on fastsync isn't a wise choice.
if it's adaptive sync, thats something both vendors have.
if you hate tearing and latency, you can pick a freesync/gsync monitor thats the best option.
Adaptive vsynch isn't the same as vsynch. Vsynch I believe handles refresh rates in steps so something like it flips between 30 and 60 if you've got a 60hz panel. Adaptive on other hand doesn't do this stepping and allows the frames to render as fast as they can but then kicks in at 60fps.
AMD Freesync, is the VESA's Adaptive sync implementation. Which is supported also by Intel.
Is using the VESA Adaptive Sync as specified by DP1.2a.
And that "Adaptive Sync" is the hardware specs of how it should work. Freesync is the driver implementation from AMD.
Also lets not forget, Nvidia, DP1.3/1.4 cards on hardware level, can support Vesa's Adaptive sync. However on driver level, such functionality is deactivated because that would make all their cards compatible with the Freesync monitors.......
What I am referring to is the monitor less support for adaptive vsynch. At present with my crappy old monitor I can use adaptive vsynch in Nvidia drivers and it will turn on and off vysnch based on fps.
Does AMD have an equivalent?
The answer I think I'm getting is no.
Thing is, if you have a freesync or g-sync monitor, there is zero need for adaptive v-sync.
Adaptive v-sync is only any good for people like me who have no freesync or g-sync monitor. But as I am looking to buy a freesync 2 monitor this year hopefully, I am not bothered.
The reason AMD likely abandoned the adaptive v-sync tech is because now with freesync in pretty much most new monitors it would be a waste of resources.
Wish there was more news on Freesync 2 monitors, from what I have seen they look like they are going to be very good. Low latency and hdr together with freesycn obviously![]()
